Setting up DDNS on ATP100 in Nebula
Do I need a Nebula Plus or Pro Pack License to add dynamic dns (DDNS) on my ATP100? I cannot find this menu over Nebula, though I had it set up previously when connecting directly through my LAN. Also - Is it normal that I am locked out of the ATP100 locally while it is connected to Nebula? Is there a way to access locally or will I need to reset for local use & how to do that? Thanks for you help.
Hi @bedfoto,
DDNS setting is at "Security gateway > Configure > Interface addressing".
In general, most configuration can be set via Nebula. local web gui is mainly for troubleshooting.
You can log in web gui locally to troubleshoot network issue if needed.0
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
