[NEBULA] VPN L2TP AND CLOUD AUTHETICATION USERS
HI all
i have upgraded my nsg50 to latest firmware..
i have created a new vpn user in cloud user, i have setup l2tp config on nsg (preshared, subnet etc)
i have created a new connection on my win10 laptop.. it doesn't work, i receive an error with this connection..
on gateway logs i receive this error: [ID] : Tunnel [L2TP_Client_VPN] Phase 2 Local policy mismatch
how can i resolve this issue??
thanks
thanks
hi ivers..
yes my nsg use private ip ... on internet router i have created a dmz from router to my nsg.. so all port are redirect on my private ip..
on security config in client side, i tryed all possible configuration but it doesn't work0 -
Hello @snowbike
In current stage we do not support the scenario that NSG behind the NAT server, however, don't worry we got the workaround for it. I will PM you.
We'll soon have the feature enhancement on this part, as well!0 -
thanks for all Nebula_Chris0
@snowbike
We actually don't have the CLI list, the L2TP case is just the workaround to support this scenario temporary it's not a long term solution, but if you have any application that NCC cannot do then it's welcome to have the converstaion in here or go to the support channel.
We'll also listen to what the customer need and have the future improvement on those limitations.
BTW, is your L2TP can work now ?0 -
no chris, but is not urgent, so i think that i wait future improvement.. thanks a lot fro support0
Hello @snowbike
I have private message you on yesterday and have attached the relevant document, too.
Have you receive it?
Please private message me If you have encounter any difficulty with the SOP.0 -
Hello I have the same scenario, can I have more info on the workaroud?0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
