Upgrade ZyWall310 to latest firmware
I need to update a router that is still running on firmware version V4.39(AAAB.0).
I have two questions:
1. In the Release Notes of newer firmwares a bug is mentioned when FQDN AdressObjects are used. Do I have to remove these Objects before upgrading?
2. According to the release notes it is recommended to follow an upgrade path as follows: 4.38+ => ZLD4.62 Patch0 => ZLD4.65 Patch1 => ZLD4.70
In the download area version 4.62 is no longer available. Can upgrade directly to 4.65?
Hi @asmgu ,1. Please follow the instructions in the attachment. (Resolution and Remarks).2. If the original firmware version 4.39 is official version, it can be upgraded directly to 4.70. We also suggest you save the startup-config.conf before performing firmware upgrade. More detailed information can be found in the following discussion.
https://community.zyxel.com/en/discussion/12409/zywall-310-firmware-upgrade1
https://community.zyxel.com/en/discussion/12409/zywall-310-firmware-upgrade1 -
Thanks for your answer!Direct upgrade to version 4.70 and now 4.71 was successful.0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
