Legacy firmware for Zywall USG 200
I'm trying to upgrade the firmware from version 2.20(AQU.1) to the latest 3.30(AQU.7) I tried to upgrade directly to the latest version but I get the error that says the firmware is not compatible, I was looking for the intermediate versions but are not available anymore from the site ftp.zyxel.com.
there is a way to recover it?
Thanks.
Thanks.
Thank you Kevin,
version 2.20(AQU.2)C0 was finally working, and after I was finally able to install in order the versions
2.20(AQU.6)C0
3.00(AQU.0)C0
3.30(AQU.5)C0
3.30(AQU.7)C0
HI,
Thanks for your fast reply!
I tried to Update the firmware version 3.0 that you sent me, I still get the error
"errno: -42008 errmsg: Firmware not compatible!"
inside the Firmware page, the model on top is "ZyWALL USG 200" so it is right the other info isBoot Module: 1.12Current Version: 2.20(AQU.1)Released Date: 2010-05-06 11:27:50
I wonder if I need all the versions also before 3.0.0 -
as you can see in the picture is what I did.
I was reading comments about this error and I found another person with the same problem with the model USG 100, he solved it by installing also all the patches in sequence, annoying but effective,
in my case, I should install in order:
2.20(AQU.2)C0
2.20(AQU.3)C0
2.20(AQU.4)C0
2.20(AQU.5)C0
2.20(AQU.6)C0
3.00(AQU.0)C0 (the one you sent me)
3.00(AQU.2)C0
3.00(AQU.4)C0
3.30(AQU.1)C0
3.30(AQU.2)C0
3.30(AQU.4)C0
All the files were available on the FTP server Zyxel, It is a pity that the files are no longer available to the community.0 -
This what your looking for
Download Library - ZYWALL USG 200 | ZyXEL
But if its not updating its likely the boot module verion is too old to allow newer firmware updates0 -
I already tried to download it from the official site but there are only 3 versions
3.30 AQU.5
3.30 AQU.6
3.30 AQU.7
and all 3 versions gave me "errno: -42008 errmsg: Firmware not compatible!"
I would guess you need 2.20(AQU.6)C0 to allow the newer firmware0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 461 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 438 News and Release
- 4.3K FAQ
- 91 Security Highlight
