Possible to add a description or rename VLANs?
TAPTech
TAPTech Posts: 174 image  Master Member
First Comment Friend Collector Seventh Anniversary Nebula Gratitude
Is it possible to add a description to VLAN's?  It would be really helpful to have a quick reference in Nebula for them.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @TAPTech,
    May I know which model are you asking?
    And may you share a screenshot with description?
    Zyxel Melen
  • TAPTech
    Hello Melen,
    USGFLEX and ATP models.  It would be nice to have an extra column here where we can add a Description.  "Printer VLAN" or "Guest WiFi VLAN", etc.
  • Zyxel_Melen
    Hi @TAPTech,
    Thanks for your sharing.
    Kindly remind that the VLAN interface can be named as other name when first setup.
    But you may not change the name after first setup.
    So may I know is the tip fulfill you purpose? Or you still need an extra column for description?
    Zyxel Melen
  • TAPTech
    I am aware that you cannot change the name afterwards, also, the name is very limited in allowable characters.  I think adding a separate description would be very helpful as a feature request.
  • Zyxel_Melen
    edited March 2022
    Hi @TAPTech,
    Thanks for your feedback.
    I had been created a new idea for this feature, please check this link or check on Nebula ideas.
    Zyxel Melen
Nebula Tips & Tricks
