hello everyone!!!,
Thanh
Thanh Posts: 4 image  Freshman Member
 How to check who has access to the system on NSG100, Thank you!
Best Answers
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,669 image  Zyxel Employee
    Hi @Thanh,
    Welcome to Zyxel community!
    Since NSG-100 is Cloud Managed Security Gateway, you may go to Security Gateway > event log to check who has access to NSG-100 via console or Telnet/SSH.
    You may select Auth option to filter the log and find the logs of logged in/out device.
    The below example is the logs that I access device via console.
    If user logged in from Telnet/SSH, you will also see the IP address the user came from.
    Hope it helps.
    Zyxel Melen
  • Thanh
    Thank you very much for this answer! but i cant see any, please help me!!
  • Zyxel_Melen
    Hi @Thanh,
    Hope it helps.
    Zyxel Melen
  • floyelam
    floyelam Posts: 1 image  Freshman Member
    Friend Collector
    edited March 2022
    Hi @Thanh,
    Hope it helps.
    Thank you so so much. This answer was very very useful to me.
  • Thanh
  • Zyxel_Melen
    Hi @Thanh,
    If you don't see the logs after you logged in, please wait for few minutes since Nebula is still getting the logs from your device.
    Zyxel Melen
Nebula Tips & Tricks
