Possible to add a description or rename VLANs?
Zyxel Melen0
Hello Melen,
USGFLEX and ATP models. It would be nice to have an extra column here where we can add a Description. "Printer VLAN" or "Guest WiFi VLAN", etc.
Hi @TAPTech,
Thanks for your sharing.
Kindly remind that the VLAN interface can be named as other name when first setup.
But you may not change the name after first setup.
So may I know is the tip fulfill you purpose? Or you still need an extra column for description?Zyxel Melen0 -
I am aware that you cannot change the name afterwards, also, the name is very limited in allowable characters. I think adding a separate description would be very helpful as a feature request.0 -
Hi @TAPTech,
Thanks for your feedback.
I had been created a new idea for this feature, please check this link or check on Nebula ideas.
Zyxel Melen1
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
