GS1900-24E with Allnet firmware
mibi
mibi Posts: 2
edited August 2022 in Switch
some time ago I bought a GS1900-24E and I wanted to integrate it into my network now. As I entered the admin interface it showed itself as an ALL-SG8324M and the most recent firmware is from 2018. I tried to install one of the GS1900 firmware but they are all rejected as being "Copy: Illegal software format".
I did not install the Allnet firmware. Is there any chance to install the original zyxel firmware on that device.
Any help is appreciated.
Michael
  • Zyxel_Adam
    Zyxel_Adam Posts: 429  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    edited March 2022 Answer ✓
    Hi @mibi,
    Welcome to Zyxel Community!
    You could check our Donwload Library out to download latest FW version for every switch.
    For donwloading latest FW of GS1900-24E, please click here.
    Note: Please use .bix file to do firmware upgrade.
    Hope it helps.
    Adam
  • Zyxel_Adam
    Hi @mibi,
    Hope it helps.
    Adam
  • mibi
    mibi Posts: 2
    Hi @Zyxel_Adam,
    It has been some time ago that I opened this request.
    As you suggested I tried to use the latest firmware but without success. The error message keeps coming up: "Copy: Illegal software format".
    And yes, I am using the bix files from the downloaded zip.
    I tried it again today because I saw that there is an updated firmware from October 2023 available but still have not luck.
    Any ideas?
    Michael
