Legacy firmware for Zywall USG 200
  • Roby70to
    Roby70to Posts: 8
    Thank you Kevin
    unfortunately, also the 2.20 AQU.6 gave me the same error.
    at that point, I would try the release 2.20(AQU.2)C0 if this version work I probably really need to install all the release in order.
    Can you please provide version 2.20(AQU.2)C0?
  • Roby70to
    Roby70to Posts: 8
    Thank you Kevin,
    version 2.20(AQU.2)C0 was finally working, and after I was finally able to install in order the versions
    2.20(AQU.6)C0
    3.00(AQU.0)C0
    3.30(AQU.5)C0
    3.30(AQU.7)C0
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,398 image  Guru Member
    Hi @Roby70to
    You can download 2.20(AQU2).C0 firmware by this link,
  • tmng
    tmng Posts: 1
    I have 2.20(AQU.4) and need to upgrade to 2.20(AQU.6) before upgrade to the latest firmware. Can you PM me the require firmwares? Thank you.
  • cehmi
    cehmi Posts: 1
    Hi
    I'm looking for 2.20(AQU.6) firmware,
    Can someone PM me with this ?
    thank you !
  • KlausDus
    KlausDus Posts: 1 image  Freshman Member
    I need to bring the firmware of my ZyWall to the latest/last released version. Currently I have Boot Module 1.12 and Version 3.30(AQU.7). Are there any intermediate steps I need to perform?
    The problem I intend to resolve is the outdated method used for HTTPS.
    Thanks and Regards, Klaus
  • Zyxel_James
    Zyxel_James Posts: 788 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    I suggest that upgrade version by version. May I know what's your current version? I will send the firmware file you need via PM.
  • kumelys
    kumelys Posts: 1 image  Freshman Member
    I currently have 2.20(AQU2), downloaded using the link above in this thread. Where can I download the latest and intermediate versions? They are not available on the zyxel website, cannot find them.
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,954 image  Guru Member
    Hi @kumelys
    ZyWall UGS 200 is an "end-of-life" model. To ensure your network security, we recommend you upgrading it to USG FLEX 200H/USG FLEX 200.
    Zyxel Melen
  • TESAC
    TESAC Posts: 1 image  Freshman Member
    Hi Kevin,
    we're also in need of upgrading an old Zywall USG 200. Is still available the list of firmware I read in this topic?
    Thanks in advance,
    Enzo
