[NEBULA] Am I doing something wrong?
mcoleman
mcoleman Posts: 2 image  Freshman Member
edited April 2021 in Nebula
<The picture has been removed due to the security concern>
  • mcoleman
    Thanks. So if I register the device, then Nebula will be able to find it?
  • Zyxel_Jason
    Zyxel_Jason Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @mcoleman,
    As I mentioned, since your device NWA1121-NI is not a Nebula device, it doesn't support Nebula feature.
    Only the Nebula device which I list in my last reply could be registered on Nebula Control Center.
    Hope it helps.
    Jason
Nebula Tips & Tricks
