Connection with fiber cable
I just got 2 Zyxel GS1350-6HP switches and installed a Zyxel SFP-LX-10-D SFP:s in both switches and connected a fiber cable between them. But i do not get any link between them. One of switches says that it has a link but the other one has no link at all. What could be wrong? Fiber cable damaged?
@MecomIT,
Could you please help to collect the tech-support file (Management> Maintenance) on both of switches (collect while the cable plugin) and attached/PM to me.
Also may I know how long is this fiber cable?Chris
Thanks for help. I will be at customer site next week and i will get these logs to you then0
Fiber optic internet is a data connection carried by a cable filled with thin glass or plastic fibers. Data travels through them as beams of light pulsed in a pattern. Fiber optic internet speeds are about 20 times faster than regular cable at 1 Gbps.
MecomIT said:I just got 2 Zyxel GS1350-6HP switches and installed a Zyxel SFP-LX-10-D SFP:s in both switches and connected a fiber cable between them. But i do not get any link between them. One of switches says that it has a link but the other one has no link at all. What could be wrong? Fiber cable damaged?
Hi what kind of Cable did you get? A Multi or Single Mode?I bought mine Adapter used from Ebay and did the Mistake by bought Single Mode Adapter like yours.What you need is a SINGLE MODE Cable! The have "OS..." in there name. "OM..." are the wrong one.Thankfully from my Distributor I found a cheap 50m Cable who work so for me its not a loss...0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
