Will Device HA work with Vlan WAN & LAN
Emerald
Emerald Posts: 36 image  Freshman Member
Ive a HA environment with 2 x Zywall 310's we planned to use Device HA on them.
It turns out the environment we are in is not using physical ports for LAN and WAN connectivity.
Ports 1&2 form a LAG upon which are two VLANS which are then the LAN & WAN of the network.
So
P1 & P2 = LAG1 with No IP address
VLAN123 on LAG1 WAN IP 1.2.3.4
VLAN234 on LAG1 LAN IP 4.3.2.1
P8 = Connectivity for heartbeat
Ive read plenty but in the device HA only talks about physical ports.
Can device HA work with VLAN's in my scenario?
Thanks in advance
  • Zyxel_Stanley
    Hi @Emerald
    This scenario is work. You can create configuration by:
    (1) Create LAG interface and binding ge1 & ge2 interface.
    (2) VLAN interface and base port is LAG interface.
    (3) Configure Device-HA Pro Setting.
    (4) Make sure Device HA mode is "Device HA Pro" and enable HA function.
