VMG Accessing ARP table from CLI
elavaud
in Home Router
Any ideas?
Thanks!
Thanks!
Hi there
I think the CLI will no open for user.0 -
Yes it is
I can already do a bunch of commands. However what is not open is the documentation... 0 -
Hello all,
There is a 2013 document of the Zyxel CLI for a VMG1312 -B10A at https://support.aa.net.uk/images/6/6c/VMG1312-B10A_CLI_Reference_Manual.pdf
It mentions a command called ARP show which might do what you would like.
Whether you have access to it depends on the level of login that you use, and the firmware version you have.
- it does not show on my VMG1312-B10D if I login with admin
Kind regards,
Tony0
- 588 USG FLEX H Series
- 477 News and Release
