XS1930 dropping ports
For a long time I've given up using the XS1930 because it would intermittently loose connectivity on a port. I could see in the log the port(s) going up and down regularly. Now I've got time to get back to it, I may have solved it (too soon to say for sure but it's looking better). The solution seems to be to hard-write the port speed for each port, rather than leaving each at "auto".
I wondered if anyone else had this problem, or can offer any relevant suggestions?
Thanks all.
@DMartin,
Are all the ports has this issue? And how often does it occurs.
Can you help to collect the tech-support file (Management> Maintenance) and PM/attached to me.
Thanks, not sure. PM sent. Could be just one attached device.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
