Securextender in WIN 11
Giuseppe69
in Security
Capita a tutti i miei client che dopo aver aggiornato il computer a WIN 11 securextender in VPN SSL alla prima connessione si disconnette dopo 60 secondi con network traffic a 0
rifacendo la connessione poi funziona tranquillamente
grazie
grazie
Hi @Giuseppe69,
For further investigation, could you provide more information?
1. Microsoft Visual C++ 2015-2019 Redistributable version
2. Microsoft .NET Framework version
3. Zywall SecuExtender version
4. Check if SecuExtender helper is running
Moreover, please provide SecuExtender.log and SeCuExtenderHelper.log in Private Message.
You could find them at
C:\SecuExtenderHelper.log
C:\Users\[windows account]\SecuExtender.log
Thank you.
James0 -
Is there any news?0
Hello @Giuseppe69, @Omnia,
We are testing the compatibility of the VPN Client with Win11.
And we will update the progress ASAP.
Thanks for your patience.
James.
I'm available for testing, @Zyxel_James if any beta is available.
My win 11 VM with SecuExtender 4.0.4.0 seems to work fine0
Tested outside a VM with TPM and it works with win 11 and passes DNS leak test only thing I have not done is a uptime test0
Doing a uptime test for 3 hours by pinging down the tunnel fine but if you connect and go idle somewhere between 10-30 ~ minutes it disconnects.
Edit so I tried to get it to disconnect when idle and now its fine for over 4 hours...odd
Edit2 Hmm this might need to be a new post for this to be looked into0 -
Some other fellows users reported that.0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 918 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 920 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 208 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
