USG110 Antispam Log truncates the subject of the email
Fred_77
Fred_77 Posts: 126  Ally Member
5 Answers First Comment Friend Collector Fourth Anniversary
Hi guys, i'm really freaking out about weird behavior on a usg110.
Apparently the antispam registry service truncates email's object randomly (but every day).
This is an example of correct email received, where the string is at the end of the object.
Subject: Avviso di scadenza: Periodo di prova, azienda: FARMACIA LA GRANDE
 S.n.c., dipendente: VENUTA MATTIA, data scadenza: 02/01/2022
X-ZyXEL-AS-Log: USG110-SN-FW02-1-WhiteList
This is an example of truncated object; the string is in the middle and the next part of the object is truncated
Subject: Avviso di scadenza: Periodo di prova, azienda: FLOW S.r.l.,
dipendente: BALBONI YLENIA, data scadenza: 12/01/2022
If Antispam log is turned off no more issues.
Firmware is the latest
Any idea?
Thanks in advance
Fred
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,317  Zyxel Employee
    Hi @Fred_77
    When Anti-spam scans an e-mail successfully and the X-header of the e-mail would be added as extra information to highlight this mail had been scanned by your USG110 device.  It's normal behavior, so don't worry about that :) .
  • Fred_77
    Hi @Zyxel_Jeff thank you for your reply...
    it would be a normal behavior if the string would be added at the end of the object... but it's added in the middle of the object, and the next part of the object is truncated.
    Example: if the object is "This is the object of the email" and  AntiSpan string is added at the end i can see the object  correctly.
    If the AntiSpam string is addedd in the middle i can see " This is the".... and the next part is lost.
  • Zyxel_Jeff
    Hi @Fred_77
    Can you share the below information with us via private message for further clarification?
    (1). the screenshots about this symptom
    (2). device configuration file
    (3). diag-info log
    (4). the e-mail file which was scanned by Anti-spam
    (5). the e-mail file which was not scanned by Anti-spam
    Thanks.
  • Zyxel_Jeff
    Thanks for sharing that information with us.
    What are your E-mail file format and its protocol?
    Can you collect e-mail packets with and without Anti-spam from the wan and lan interface for us?
    Once you have done, please provide the packet files to us via private message.
