USG210 admin password
Pin the reset button on the front panel for 10 seconds and it will reset your admin password.1
All of configuration be reset.
If you would like to keep your configuration, you can follow these stpes to backup old configuration and reset admin password.
https://community.zyxel.com/en/discussion/1558/how-to-backup-running-configuration-if-forgot-password
Why does this happen? This has just happened to me for the 2nd time in the last few years and it's very annoying to have to reset and restore our config.0
Hi @jw708
Did you configure character doesn't belonging to ASCII code?
Which firmware version occurred the issue? You can upgrade to latest version(4.71) first and make sure if it helps. New firmware could backup configuration by schedule and send to your mail server. Restore configuration steps is much easier than previous steps.
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
