ZywallATP100 keeps booting
CharlyBrown
in Security
In the last days the network appeared being slow, despite the router being up to speed. Therefore, rebooted the Zywall. Now, it doesn't startup correctly anymore and cannot be reached.
LEDS:
PWR: constant green
SYS: blinking green (for 2 hours or so)
Ports: all off
LEDS:
PWR: constant green
Ports: all off
Last active FW: 5.00
Looking forward to your guidance. Thx
Tried a hard reset - but that didn't have any effect either. Therefore, have sent it now to the technical service point of Zyxel. Let's see what they say.
I have the same problem!
did you get an answer?
@Davide_CUD - No, not yet. The device is on its way to the manufacturer. Knowing that someone is interested in the outcome, I'll post the result here hopefully next week.
You need to update the firmware, see the following post:
@Mario Thank you for that hint - however, if the Zywall device doesn't startup any more and cannot be reset, then I would not know how to patch the firmware...
Hello @CharlyBrown, @Davide_CUD,
If your device was suffering device hang after reboot, please refer to these article to recover the device.
Thanks!
James.
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
