Securextender in WIN 11
Giuseppe69
Giuseppe69 Posts: 1  Freshman Member
Second Anniversary
Capita a tutti i miei client che dopo aver aggiornato il computer a WIN 11 securextender in VPN SSL alla prima connessione si disconnette dopo 60 secondi con network traffic a 0
rifacendo la connessione poi funziona tranquillamente
grazie
  • Zyxel_James
    Zyxel_James Posts: 754  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hi @Giuseppe69,
    For further investigation, could you provide more information?
    1. Microsoft Visual C++ 2015-2019 Redistributable version
    2. Microsoft .NET Framework version
    3. Zywall SecuExtender version
    4. Check if SecuExtender helper is running
    Moreover, please provide SecuExtender.log and SeCuExtenderHelper.log in Private Message.
    You could find them at
    C:\SecuExtenderHelper.log
    C:\Users\[windows account]\SecuExtender.log
    Thank you.
    James
  • Omnia
    Omnia Posts: 57  Ally Member
    Is there any news?
  • Zyxel_James
    Hello @Giuseppe69, @Omnia,
    We are testing the compatibility of the VPN Client with Win11.
    And we will update the progress ASAP.
    Thanks for your patience.
    James.
  • mMontana
    mMontana Posts: 1,428  Guru Member
    I'm available for testing, @Zyxel_James if any beta is available.
    PeterUK Posts: 3,788  Guru Member
    My win 11 VM with SecuExtender 4.0.4.0 seems to work fine
  • mMontana
    @PeterUK your VM includes also a compliant TPM?
    edited April 2022
    Tested outside a VM with TPM and it works with win 11 and passes DNS leak test only thing I have not done is a uptime test
    edited April 2022
    Doing a uptime test for 3 hours by pinging down the tunnel fine but if you connect and go idle somewhere between 10-30 ~ minutes it disconnects.
    Edit so I tried to get it to disconnect when idle and now its fine for over 4 hours...odd
    Edit2 Hmm this might need to be a new post for this to be looked into
  • mMontana
    Some other fellows users reported that.
    I might of had another issue that causes disconnects so far its been fine now
