Connection with fiber cable
I just got 2 Zyxel GS1350-6HP switches and installed a Zyxel SFP-LX-10-D SFP:s in both switches and connected a fiber cable between them. But i do not get any link between them. One of switches says that it has a link but the other one has no link at all. What could be wrong? Fiber cable damaged?
@MecomIT,
Could you please help to collect the tech-support file (Management> Maintenance) on both of switches (collect while the cable plugin) and attached/PM to me.
Also may I know how long is this fiber cable?0 -
Thanks for help. I will be at customer site next week and i will get these logs to you then0
MecomIT said:I just got 2 Zyxel GS1350-6HP switches and installed a Zyxel SFP-LX-10-D SFP:s in both switches and connected a fiber cable between them. But i do not get any link between them. One of switches says that it has a link but the other one has no link at all. What could be wrong? Fiber cable damaged?
Hi what kind of Cable did you get? A Multi or Single Mode?I bought mine Adapter used from Ebay and did the Mistake by bought Single Mode Adapter like yours.What you need is a SINGLE MODE Cable! The have "OS..." in there name. "OM..." are the wrong one.Thankfully from my Distributor I found a cheap 50m Cable who work so for me its not a loss...0
- 588 USG FLEX H Series
- 476 News and Release
