Bandwidth limitation on WAN ports?
The USG40W is a bit of a light wight it may be listed as 400Mb but that is for UDP TCP is around 200Mb is what your seeing.
You may make it faster by going to monitor > system status > traffic statistics and uncheck Collect Statistics then apply.
You can also go to configuration > system > advanced and check enable but that disables some stuff you might need.
7
7 -
Hi @LuizOrlandi,
Welcome to Zyxel community.
For better performance experience, we would suggest replace to ATP/FLEX series.
https://www.zyxel.com/products_services/ATP-Firewall-ZyWALL-ATP100/license-and-spec
Nice.
Customer ask "Hi, my device is slow. You listed performance 100, but with 50 it stutters"
Zyxel answers "Hi, you can consider to buy a newer device".
Maybe the advertised specs should be a bit more... thruthful?1 -
Hi @mMontana,
Thanks for your feedback. In the USG40/W data sheet, maximum throughput based on RFC 2544 (1,518-byte UDP packets), it measure in UDP. As for online speed test, it run in TCP. That's why we can see the difference.
Why not put also UDP traffic limit into specifications as among
VPN
SPI
IDP
and so on?
Sorting the data from the lowest value.1 -
Thank you Peter ! It really improve the performance, now I can reach 270 mb/s in a connection that barely was reaching 200mb/s.
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 661 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
