USG110 cuts off the internet or does not filter.
Thanks for the answer. I do not know if we understand each other. I want the Router UNIFI to be responsible for the management of the VLAN. Does your suggestion include this?0
Hi @Jakub
Welcome to Zyxel Community.
In your environment, the subnet 10.10.6.x should working….but VLAN subnet 192.168.54.X is not working.
Did you setup VLAN interface on USG110?
You can create a VLAN fulfill your environment.
Zyxel_Stanley said:
Hi @Jakub
Hi Jakub
If you would like to managing VLAN subnet by Unifi gateway, then you can setup bridge interface on USG110.
Create a bridge interface. (Configuration > Network > Interface > Bridge > Click “Add” button)
a. Add WAN1 and LAN2 as bridge interface member.
b. Setup interface management IP.
c. Must disable DHCP server function.
Unifi Gateway connect to USG110 on port 1.
Unifi Switch connect to USG110 on port 4.
The bridge has already been created (WAN-> LAN1). How to connect USG110 for Gateway on the 10.10.6.x network is the internet and filters, but the subnet (VLAN) 192.168.54.1 cuts me off from the internet.0
Hi Jakub
If placing USG110(bridge mode) between Unifi Gateway and switch, it is unable pass VLAN tag to swtich.
If you would like to protecting your network environment, how about replace Unifi gateway as USG110. It can management LAN/VLAN subnets and also protecting network traffic by UTM function.
Thank you.0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 87 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 916 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 912 Nebula FAQ
- 420 Security FAQ
- 237 Switch FAQ
- 207 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
