Bridging VLAN with physical port
This is my config. I see you use general interfaces, while I have internal. Could it be the case?
I have the "internal" interface types, however switching to general did not help either.
Really weird behavior.
The only differences i can see are:
i created a new zone "Br1 Zone" and all the interfaces have an ip address (base port, vlan etc..).
Time ago a guy from zyxel told me don't leave 0.0.0.0 when you have multiple virtual interfaces on the same port0 -
To amend this, did not help. If I remove VLANs from the equation, the bridge works. With VLANs, not at all ....0
If a interface or bridge don't need a IP what I do is set them up with a 127.255.0.0/30
A layout drawing with IP's might help?
Well, did not help. I have suspicion there is a problem with how the bridge handles tagging...0
It shouldn't be that.
I quote PeterUK, could you post a layout with IP's?0 -
Agree PeterUK, Could you post layout IP?
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 508 USG FLEX H Series
- 327 Security Ideas
- 49 Wireless Ideas
- 288 Service & License
- 458 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
