Guest Wifi with Captive Portal
TheMichaelOne
in Nebula
I'm running 5 APs (NWA50AX) with one SSID. Now I want to add a Guest Wifi. It's runinng but I don't get the desired captive activated. The option is greyed out although the captive portal is configured. Any ideas?
Hi Sir,
The NWA50AX doesn't support captive portal function, so the setting will be grey out when there're only NWA50AX registered in your site.
(For detail information, kindly refer to the "device function table" https://nebula.zyxel.com/cc/ui/index.html#/help/device-function-table )
Best Regards,
Richard0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
