Bridging VLAN with physical port
2»
  • This is my config. I see you use general interfaces, while I have internal. Could it be the case?
  • I have the "internal" interface types, however switching to general did not help either.
  • Fred_77
    Fred_77 Posts: 141 image  Ally Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    Really weird behavior.
    The only differences i can see are:
     i created a new zone "Br1 Zone" and all the interfaces have an ip address (base port, vlan etc..).
    Time ago a guy from zyxel told me don't leave 0.0.0.0 when you have multiple virtual interfaces on the same port
  • To amend this, did not help. If I remove VLANs from the equation, the bridge works. With VLANs, not at all ....
    PeterUK Posts: 4,132 image  Guru Member
    edited April 2022
    If a interface or bridge don't need a IP what I do is set them up with a 127.255.0.0/30
    A layout drawing with IP's might help?
  • Well, did not help. I have suspicion there is a problem with how the bridge handles tagging...
  • Fred_77
    It shouldn't be that.
    I quote PeterUK, could you post a layout with IP's?
  • WJS
    WJS Posts: 156 image  Master Member
    5 Answers First Comment Friend Collector Third Anniversary
    Agree PeterUK, Could you post layout IP?
