GS1900-24EP Startup - Running Configuration
Hey community,
sometimes I have the problem, that I cannot reach the configuration webpage of my switch. The reset button couldn't solve the problem, therefore I restored the factory defaults. This a a lot of work and always a network breakdown, even its on my home, that cant be a final solution.
I tried to find out the reason for that problem.
The first thougt was that something is wrong within the configuraton settings, there are the running configuration and the startup configuration. If I download the running configuration, I can find my changes inside. If I do the same with the startup configuration the file seems to be the factory defaults. Even if I copy the running conf. into startup conf. by this function:
A new download (Backup) of the startup conf. show no difference, seems again to be factory defaults.
According to the manual the switch is using startup conf during booting.
My switch seems to do something in between.
In my tests now, it saves changes (network config, admin passwort etc.). These values are surviving a reboot and a power shutdown. Thats strange for me, because according the startup file I assumed another behaivior.
Firmware is this version: V2.70(ABTO.1) | 01/11/2022
Can somebody explain me this behaivior. Do i something wrong?
Alkazar
Alkazar
Hi @Alkazar,
Welcome to Zyxel Community!
Have you tried to change a different broswer and see if it's a browser cache issue?Adam
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
