HTTPS Domain Filter USG Flex100
Hello, with my USG 100 the following is always blocked by the HTTPS Domain Filter: update.production.ac2-badlion.esl.systems:unrated, Rule_name:LAN1_Outgoing, SSI:N (HTTPS Domain Filter). What can I set so that this is not blocked. Turning off HTTPS filters is not the solution.
greeting
Marcus
Hi @Niro96The log message shows it was blocked by the Web Content filter category 'Unrated' that be applied on LAN1_Outgoing security policy.So, you can adjust the Web Content Filter setting item of 'Action for Unrated Web Page' to Pass or Warn with log to avoid this, as below:
Trusted Web Sites tab?
I tried. I just don't know which WEBSite I have to enter there. Not clear from the message.
thanks for your Reply. It works now. I deactivate the Web Filter and use the DNS Filter now.1
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 501 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
