High cpu usage on USG40w
IT_Field_Support
IT_Field_Support Posts: 97 image  Ally Member
We have an issue on one of our router.
CPU is always 99%.
I check the settings, tried to disable CF, Secureporter, logging etc.. without founding the cause of the high cpu usage.
In console i can see that this process is always high :
31006 31001 python          root     ?         19   0 51.0  0.5 R     11856  5712  3432  2964 09:59:43       00:03 00:00:01 python /usr/sbin/reg_agent.pyc 1 16b37c4cc5a135c075ede86977a6052daf436608c3aee5e788b2ff80 4.70(AALB.0)
Router is really slow.
Thanks for support
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    Any IPSec VPN active?
    USG40 with ... 6mbyte/s of SMB transfer on VPN (Ikev2, AES256) have CPU Stuck around 92-99%
  • Zyxel_Cooldia
    The process /usr/sbin/reg_agent.py shoule be done in short time.
    Can you provide device web gui access in PM. We would like to check this device status.
