Xyxel USG60W start up issue
Dovetail_MD
Dovetail_MD Posts: 81  Ally Member
edited April 2021 in Security
I have just got a USG 60 W on test and am having trouble logging into it.
I can get to the web page which is the front-end for the unit.
I put a password in which is my usual standard against my usual username and it will not allow me to login.
I'm running a browser on a Windows 10 pro laptop attached to the USG 60 W and have tried both Firefox and Microsoft edge without success.
Resetting the item does not seem to have any effect
Does anybody have any advice?
  • Dovetail_MD
    also now tried Chrome - java script is on, cookies not blocked
    PeterUK Posts: 3,892  Guru Member
    edited August 2018
    Reset it (hold reset in for 20 sec) and try again when you log in with admin and 1234 try a simple password then log in with admin and that simple password as a test before your better password to see if it happens again.
  • Dovetail_MD
    yeah - simples - load Opera and off we go
  • ChrisGer
    ChrisGer Posts: 206  Ally Member
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    Hi Dovetail_MD
    i've a restart issue and in contact with ZYXEL to fix the located issue by a reboot.
    regards
    Christian
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @PeterUK
    Thanks for your sharing. :)
    @Dovetail_MD You can try to reset device and try default username and password again.(admin/1234)
