Xyxel USG60W start up issue
Dovetail_MD
I have just got a USG 60 W on test and am having trouble logging into it.
I can get to the web page which is the front-end for the unit.
I put a password in which is my usual standard against my usual username and it will not allow me to login.
I'm running a browser on a Windows 10 pro laptop attached to the USG 60 W and have tried both Firefox and Microsoft edge without success.
Resetting the item does not seem to have any effect
Does anybody have any advice?
yeah - simples - load Opera and off we go0
also now tried Chrome - java script is on, cookies not blocked0
Reset it (hold reset in for 20 sec) and try again when you log in with admin and 1234 try a simple password then log in with admin and that simple password as a test before your better password to see if it happens again.
Hi Dovetail_MDi've a restart issue and in contact with ZYXEL to fix the located issue by a reboot.regards
Christian0 -
Hi @PeterUK
Thanks for your sharing.
@Dovetail_MD You can try to reset device and try default username and password again.(admin/1234)0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
