pairing license securepoter HA
Pippo
Pippo Posts: 13 image  Freshman Member
Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate First Comment Friend Collector
edited August 2022 in Service & License
Hello, I have just activated the ha pro mode of two usg flex 700s, I have paired the bundled utm licenses and the status is perfectly transferred to the primary device. I noticed that secureporter licenses are not being transferred is it possible?
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 958 image  Guru Member
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Pippo,
    Greeting Forum, Could you provide your SN/MAC in Private Message ?
    We would like to check the License status .
    Kevin
  • Zyxel_Kevin
    Hi @Pippo,
    Kevin
  • Zyxel_Kevin
    Hi @Pippo,
    Thank your Private Messages.
    Trial license won't transfer. So it is the normal behavior.
    Kevin
  • Pippo
    OK thank you
Service & License Help Center
