USG110 - 2FA SMS has no code in text message
Oh - it's firmware version V4.71(AAPH.0)0
We're seeing the same thing on all of our devices USG and ATP that have the latest firmware. We're going to flip to email for now....0
Dear Customer,
After we checked, We have the correct mail content send to Clicksend.
(Capture in WAN interface)
However,Clicksend only send Subject to Phone.We will contact clicksend/smsglobal to check the issue.
Thanks.
Kevin0 -
Hello,same problem with Zywall 110 and clicksend (tested with firmware version 4.70 and 4.71).4 options in clicksend1) I receive the SMS with subject only and ":"2) I receive the SMS with subject only3) I dont' receive the SMS4) I dont' receive the SMSI never receive the url linkI have tested with start and stop message {sms} {/sms} (Clicksend options) and test with "default message" and multilangual file in firewall configuration, same results.example body of message for 3 and 4Can we remove HTML code for email send to SMS ?ez_
Hi Customer,
Clicksend don't allow text/html. We will impove on next ZLD(5.30/4.72)
After install Firmware,You could change type yourself by CLI .Router> debug system email-to-sms-encoding inactive ->text/plain
Router> debug system email-to-sms-encoding active -> text/html
On the other hands, For "VPN Access" scenario , Some SMS Service Provider might verfiy customer before allow to insert URL. So if you didn't receive 2FA code of VPN Access , Please check with Service Provider.
Kevin
When is 5.30 supposed to be released? Is there an alternative to ClickSend that you support?0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
