USG Flex 200 with Fritzbox 7390 as Modem
baba
baba Posts: 280 image  Master Member
edited April 2022 in Security
Hello! I deleted the provider access data in my Fritz!Box 7390 and enabled PPPoE passthrough. Then I connected an RJ-45 from LAN1 in the Fritzbox to WAN in the USG. Started the USG and plugged in the USB stick when the LED was green. What am I doing wrong? How can I debug it better? ztpresult.log 2022/04/18 07:18:48|USG FLEX 200|SN:S212L32103578|Firmware:5.21(ABUI.1)|Connect to fqdn [https://d-a.nebula.zyxel.com] fail!
  • Zyxel_Cooldia
    Hi @bada,
    You may check if your network DNS query can resolve FQDN d-nebula.zyxel.com.
    Following Nebula server FQDN list for your reference.
  • Zyxel_Cooldia
    Hi @bada,
