Pin Client to specific Access Point
PEACEkeeper
Is it possible to pin clients to a specific access point?
My scenario:
I've got two NWA50AX, one is connected to the switch and the other one is acting as repeater. Both APs are serving the same SSID.
Now, some clients are connected to the repeater, because of the better signal. But (for some reasons) they should better use the main AP.
In my old setup, this was done by managing allow/deny lists containing the client MAC on each AP (which was not nice to handle).
Is there some way in Nebula to do this using policies?
My scenario:
Hi @PEACEkeeper
Nebula doesn’t support stick client to dedicated AP so far, from your description we suggest to configure smart steering and set proper threshold to handle client connect in the range.
https://community.zyxel.com/en/discussion/10008
Thank you
Regards,
Bella
Hi @PEACEkeeper
Thank you
Regards,
Bella
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
