Help with planning a small network using Zyxel hardware
davids355
davids355 Posts: 2 image  Freshman Member
edited August 2022 in Switch
Hi guys,
I am planning on setting up a small network using Zyxel hardware. I wanted to ask whether the hadware that I have chosen will work in the required way.
My requirement is to have several (3-4) subnets that are completely segragated from eachother, but sharing a single internet connection.
I am planning on purchasing the following Zyxel switch -
Zyxel GS1900-48HPv2
Along with the following Zyxel VDSL/ADSL router -
Zyxel XMG3927-B50A
If I understand correctly, I can create multiple VLANS, each with their own LAN Subnet, DHCP server and gateway address, in the router and then route traffic for each of these VLANS via the switch.
Is that a sensible way of doing it and do I have the correct hardware choices?
    PeterUK Posts: 4,284 image  Guru Member
    The Zyxel XMG3927-B50A is simple home router with one subnet you need like a VPN100 and AP
  • davids355
    Thank you Peter, I will have a look at the VPN100 in that case. Did not realise that.
