Bring a NWA5123 back into USG management
I deleted one of my NWA5123-AC access points from my USG controller by, Config -> Wireless -> AP Management -> Select the AP and click Remove.
After this the AP went into Standalone mode. How do I get it back into managed mode? It looks like the newer firmware no longer has the option to set the AP. I've tried using the reset button as well as flashing firmware.
I've solved this one... after a while the AP showed up as a rogue AP in the USG management. It was easy to adopt after that.0
- 441 Beta Program
- 530 USG FLEX H Series
- 332 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
