Can I use the (USG20-VPN) as a Firewall Only between my Cable Modem and my Router?
TheVannMan
in Security
I am in the process of purchasing an (USG20-VPN) but I must know first if it an be used as a Firewall only between my Cable Modem and my Router.
Well it meant to be used with your modem so sure it will work keep in mind the USG20-VPN might not get more then 200Mb or less TCP speed from it. With the router you have does it do NAT? Was you hoping to firewall devices from the router? can NAT be disabled on that router or can be used as AP by not using the WAN port.
Hi @TheVannManWelcome to Zyxel community.It should be OK. But if you would like to deploy the more powerful UTM service in your environment, you could consider our USG Flex100 model.0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
