[Release Note] Access Point Series - V6.30 P4 firmware has been released!
Access Points Firmware Release Note V6.30 Patch 0
Date: January 10, 2022
Supported Platforms
NWA110AX V6.30(ABTG.0)
NWA1123ACv3 V6.30(ABVT.0)
NWA210AX V6.30(ABTD.0)
WAC500 V6.30(ABVS.0)
WAC500H V6.30(ABWA.0)
WAX510D V6.30(ABTF.0)
WAX610D V6.30(ABTE.0)
WAX630S V6.30(ABZD.0)
WAX650S V6.30(ABRM.0)
New Feature and Enhancements
1. Support new AP model. The WAX630S is added to Nebula in this release. WAX630S is a NebulaFlex Pro AP that comes with 3 management modes: standalone, controller managed and Nebula cloud managed modes. It comes with 1 year NCC Professional Pack license bundled.
2. Added IP Reputation Filter and Application Visibility & Optimization security services on the selected models. These features require CNP or CNP+ license.
3. Support forwarding AP traffic to a local Nebula managed USGFLEX or ATP via GRE tunnel, as known as “tunnel mode”, on the supported models.
4. Added Traffic Shaping feature to limit the bandwidth usage per VLAN. This feature requires Pro-Pack license.
5. Captive Portal can set the max number of simultaneous logon devices per account.
6. Support Airtime fairness feature on the selected WiFi 6 models.
7. Allow specify uplink AP for a smart mesh repeater.
8. Enhance Wireless health to avoid disconnect caused by optimization actions. There are 3 level of optimization available. This feature requires Pro-Pack license.
9. WAC500H specific improvements: Add LAN port support when using NAT. Option to include Ethernet traffic in Secure Tunnel for RAP. Live tool supports showing wired stations.
10. Rename SSID related menus for better UX: SSID overview -> SSID settings, SSID settings -> SSID advanced settings.
11.
Enhance user experience for small business AP to
prevent unsupported features.
Bug Fix
Empty column stands for the mode is unaffected.
Mode |
CLD |
MGNT |
STD |
1. [eITS: 210200458] [Symptom] The station cannot connect to the hide SSID with NAT mode |
V |
2. [eITS: 210300167] [Symptom]
Security name can’t be queried, the event log will show auth failed(AAA
Profile: null) |
V |
3. [eITS: 210400642] [Symptom] Mesh SSID is visible |
V |
V |
V |
4. [eITS: 210800912] [Symptom]
SSID schedule one hour late when daylight saving enable |
V |
5. [eITS: 210900596] [Symptom] Act-session ID in access stage is different to accounting stage |
V |
V |
V |
6. [eITS: 210900996] [Symptom] AP offline due to null pointer |
V |
7. [eITS: 210901584] [Symptom]
User sometimes can still connect even block policy is applied to SSID |
V |
8. [eITS: 211000246, 211000248, 211000108] [Symptom]
SSL error on captive portal login |
V |
9. [eITS: 210601446] [Symptom] kernel oops makes AP keep rebooting |
V |
V |
V |
10. [eITS: 210901309] [Symptom] Wireless health recovery event log display bug |
V |
11. [eITS: 211001453] [Symptom]
IPTV stream stock connecting to NWA210AX LAN port |
V |
V |
V |
12. [eITS: 211100112, 211101147] [Symptom]
NWA1123ACPRO / LED turns off after mesh is connected |
V |
V |
V |
Known Issue
Mode |
CLD |
MGNT |
STD |
1. [eITS: 211001434] [Symptom] Clients can have Internet access without entering a voucher code when connecting to SSID if wireless clients use specific VPN application | V | V | V |
2. [eITS: 211200358] [Symptom] Enable
fast roaming may cause DPPSK users run into unexpected VLAN assignment | V |
3. [Symptom] STA connects to AP LAN port can’t redirect block page if IP reputation filter is enabled and lan port vlan id is different to with managed vlan id | V | ||
4. [Symptom] Wireless Bridge Vlan Setting may not work in specific configuration procedure | V | V | V |
5. [Symptom] STA Rx Rate is always shows 1201M if WAX650S channel width set as 160Mhz and Channel as Band 2 | V | V | V |
6. [Symptom] WAC500H may encounter IP conflict for LAN interface when adding to Nebula site | V |
7. [Symptom] Application visibility & optimization feature and IP Reputation Filer feature may operate or show unexpected statistics in repeater mode | V |
Limitation of Settings:
N/A
Patch 1 (Released on 2022-2-9)
New Features and Enhancements
N/A
Bug Fixed
[Symptom]
WAC500H may encounter IP conflict for LAN interface when adding to Nebula site.
Patch 2 (Released on 2022-3-7)
N/A
Bug Fixed
1. AP may not send traffic on specific VLANs while the uplink port is link down more than 3 minutes in Continuous PoE switch deployment.
Patch 3 (Released on 2022-4-11)
N/A
Bug Fixed
Fix vulnerabilities CVE-2022-26531 and CVE-2022-26532.
Patch 4 (Released on 2022-5-5)
Supported Platforms
NWA110AX V6.30(ABTG.4)
NWA210AX V6.30(ABTD.4)
WAX510D V6.30(ABTF.4)
WAX610D V6.30(ABTE.4)
WAX630S V6.30(ABZD.4)
WAX650S V6.30(ABRM.4)
N/A
Bug Fixed
1. [eITS: 220200049]
[Symptom]
rrm: fix some STA's tx/rx always being 0
2. [eITS: 211200432]
[Symptom]
zy_dynamic_vlan: return failed when waiting too long
3. [Symptom]
Fix 802.1X dynamic vlan + 11r failure for QCA 11AX AP, Prometheus, and Galaxy
QCA Aps
Zyxel Nebula Support
Looks like another version was released last night for my nwa210ax.... No download or release notes available.0
The patch 4 update V6.30(ABTD.4) for my NWA210AX does not show up in Nebula. Nebula says: All APs are up to date (running patch 3; ABTD.3).
The update ist also not available in the Zyxel download library.
Was the patch 4 update pulled?0 -
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
