vmg3625-t50b Router Firmware
Amr
in Home Router
i bought Zyxel vmg3625-t50b router from IPS and i wanted to change this IPS but they told me that i will not be able to use the router with another SP as its locked. Thus can i change the Firmware and use it with another SP. Is there any solution or i lost my money that i bought this router with.
If there are a firmware that i can use, which default login users and pass will i be able to use?
thanks
thanks
check your inbox
2 -
i need to please0
send me pleaseSSHOUKRY said:check your inbox0 -
هل ارسل لك الباسورد
ممكن التحديث لو سمحت مرفق مع كلمة السر
could any one send me the upgrade please
thanks..
Send it please.
ممكن السوفت؟
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
