Where is the cost for ipsec vpn, I can't find where to purchase it
ActiveTechMonroe
ActiveTechMonroe Posts: 3 image  Freshman Member
edited August 2022 in Service & License
I have been going in circles for it seems hours,  I found out the SSL VPN will not work with Windows 11 and RDP the hard way but the IPSEC does. I can't find where to get the license (perpetual) ,  and  I am unable to get the zero trust one to work.
  • Zyxel_Vic
    Zyxel_Vic Posts: 321 image  Master Member
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @ActiveTechMonroe
    You can purchase both "SecuExtender, Zero Trust IPSec VPN Client Subscription Service for Windows/macOS 1-user, 1 Year" and "SecuExtender, IPSec VPN WINDOWS Client (perpetual version) version from Marketplace portal directly (https://marketplace.zyxel.com/)
    Where to buy:
    1. Login to Marketplace portal
    2. Select "Manual -Activation" tab
    3. In the "Connectivity & Vertical" section, click "VPN Client" icon, then you'll see the purchasable SecuExtender VPN Client versions in the page
    By the way, can you describe further regarding to "I am unable to get the zero trust one to work"?
Service & License Help Center
