SSL Configuration For firewall in NCC
businessuer
in Nebula
I read through the documents and SSL configuration for firewall and it mostly describe by use of the GUI not NCC portal.
1) Is there documentation for ssl configuration of firewall through the NCC?
2) For SSL VPN tunnelling, is it possible for the zyxel firewall WAN interface to be connected to the ISP router LAN interface? Or should the zyxel firewall wan interface get a public ip address directly?
Hi @businessuer
Currently, we don’t support SSL VPN scenario on Nebula mode.
You may consider IPsec or L2TP VPN scenario.
Thanks.
Can you put in a feature request for me please?
Thanks.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 482 News and Release
