What is the lock in rate limiting For?
businessuer
businessuer Posts: 134 image  Ally Member
edited November 2023 in Nebula
Can anyone explain what this "lock" in the rate limiting is used for?
What happens if you click on it ?
  • Zyxel_Jay
    Zyxel_Jay Posts: 226 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    edited May 2022 Answer ✓
    @businessuer
    Welcome Zyxel Community
    If you want to let upload and download at the same speed, you can lock it. When you alter one of downloads or uploads, the other will set the same speed as your setting.
    Zyxel_Jay
  • Zyxel_Jay
    @businessuer
    Zyxel_Jay
  • businessuer
    If I lock it, both have to be the same?
    Thanks!
  • Zyxel_Jay
    Yes, you're right.
    Zyxel_Jay
Nebula Tips & Tricks
