SSL Configuration For firewall in NCC
businessuer
businessuer Posts: 134 image  Ally Member
I read through the documents and SSL configuration for firewall and it mostly describe by use of the GUI not NCC portal.
1) Is there documentation for ssl configuration of firewall through the NCC?
2) For SSL VPN tunnelling, is it possible for the zyxel firewall WAN interface to be connected to the ISP router LAN interface? Or should the zyxel firewall wan interface get a public ip address directly?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @businessuer
    Currently, we don’t support SSL VPN scenario on Nebula mode.
    You may consider IPsec or L2TP VPN scenario.
    Thanks.
  • businessuer
    Can you put in a feature request for me please?
    Thanks.
Nebula Tips & Tricks
