Channel change to crowded channels for apparently no reason.
Chevelle
Chevelle Posts: 5
Second Anniversary
image  Freshman Member
edited May 2022 in Nebula
The logic on this is confusing.
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 525
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    image  Zyxel Employee
    edited May 2022
    Thanks for consulting Nebula support!
    Actually, the candidate selecting mechanism of DCS considers many attributes, such as noise floor, the sum of RSSI, channel utilization, channel penalty time, and max regulatory power.
    DCS calculates the weights of indicators mentioned above by the complex algorithm from all channels and thus, selects the best result.
    Could you kindly help us to tell if there is any issue with DCS from your scenario?
    There is another way that you can set up the channel manually from the AP radio setting if you want to give it a try!
    But we still suggest users use DCS since we are constantly working to strengthen the functions of DCS in every firmware version upgrade for the best choice.
    Best Regards,
    HsinBo
Nebula Tips & Tricks
