Upgrade firmware
Rezapatrol
in Home Router
Good day all....I'd like to upgrade my router Zyxel VMG1312-B10D router which current version is V5.11(ABDS.3)C0......any link to download most proper file would be appreciated.
Hello, I bought this router on Facebook makert place and I was trying to upgrade it and it kept saying illigal image..... My router is vmg1312-b10d0
Hello @PrincePrince said:Hello, I bought this router on Facebook makert place and I was trying to upgrade it and it kept saying illigal image..... My router is vmg1312-b10d
There is a thread at https://community.zyxel.com/en/discussion/7553/vmg1312-b10d-firmware-upgrade-error that you might find useful. I posted on it when I was upgrading my VMG1312-B10D.
If you have the firmware in your VMG1312-B10D that has AAXA in its name, then you should be able to use the latest firmware available at https://support.zyxel.eu/hc/en-us/articles/4403361365778-Advanced-Downloads-for-CPE-devices in it.
Otherwise, you will have a harder upgrade path, that will involve you opening up the device case.
Kind regards,
Tony0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
