What Do you configure for the URL in DDNS Settings For Firewall?
businessuer
businessuer Posts: 134 image  Ally Member
An example will be good.
  • CHS
    CHS Posts: 181 image  Master Member
    edited May 2022
    I use no-ip as my DDNS server. (I used 2 DNS records for free)
    It looks there is no additional URL setting.
    What do you mean URL?  what's your DDNS server
  • businessuer
    I referring to nebula NCC portal for FW.
    The URL there.. in red
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @businessuer'
    The URL is defined by DDNS server.
    For No-IP server, the URL setting will be "/nic/update?"
    You may have a check what's HTTP(s) request is required for your DDNS server.
    Or you can use the supported DDNS servers in the list.
