USG60 unable to get pass step 3 Easy Mode setup wizard
I just got an USG60 and try to setup the unit (firmware 4.25). While going through the setup wizard, I could not get pass step 3 as it keeps on saying the unit is unregistered, even though it is registered and activated after checking myzyxel website. I tried to reset the device but no luck, and there's no skip button or an option to switch to expert mode.... Any suggestions on steps to resolve the problem? Thanks!
Luke
Luke
Solve the problem after calling tech support. Basically update the firmware to v4.71 using Zyxel One network utility with npcap. Then I was able to get pass step 3 registration check and rest of the setup process.
Thanks Peter.0
Is their no exit option?
is it connected to the internet?0 -
Hi Peter,
Yes it's connected to the internet. I can get pass the connection check (step1) and also the time zone setting (step2).
The wizard does not have "Skip" button at step 3, only exit/back/next and also the "X" on the top right corner of the wizard. If I click exit or "X" to close the wizard, it just log me off and return to the login page.
Luke0 -
Thanks Peter.0
- 441 Beta Program
- 532 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
