Remove Management from USG firewall to Other
Ok, great! Thank you very much!
in config > wireless > AP management
and in config > wireless > controller set to manual
Hi Lucca,
Welcome to Zyxel community!
AP uses default method broadcast to find controller, you can remove APs like PeterUK’s instruction then unplug devices from USG60 and place new controller into the topology.
If you assign dedicated controller IP for AP to find, you must change the IP to the newer controller.
But for the wireless settings, we don’t support re-load config file on different controller models. It’s better setting up manually before move the APs to new controller.
Regards,
Bella
Ok thanks for the quick reply. My question is also if the ZAC software can be considered an Access Controller for AP management like the one integrated in the USG60. Thanks again0 -
Hi @Luca_S
We don’t suggest you to use ZAC because ZAC is not maintained and many features not supported.
Both Controller and Nebula is recommended for your case, especially Nebula is suitable and easily to managed 7 AP units with 2 SSIDs and MAC filter.
With Nebula, you won’t worry about to re-config the profiles if new devices added.
Don’t hesitate to get it a try and come back with your feedback.
Quick Start to create Wireless network with Nebula Control Center
Regards,
Bella
Exactly what I needed! You just saved me several hours. Thanks!
- 243 Nebula Ideas
- 6.9K Security
- 785 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 58 Wireless Ideas
- 7.3K Consumer Product
- 325 Service & License
- 528 News and Release
- 102 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
