USG Flex 200 - L2TP over IPsec, not working after firmware 5.30
Hello there
After upgrading Flex 200 from firmware 5.20 to 5.30, our users cant sign in anymore.
Anyone get the samme error.
We are using RADIUS for Duo.
If we create a local test-user in the Flex200, its works.
But then our duo/2-factor not working
Solution is to run users on the "Local"
So radius is not working anymore.
Verify the paths and credentials for accessing from USG Flex 200 to Radius. Also, change log details for debugging if the appliance can:
- contact the server
- access the server
- query the user
- and the user data is provided back to the device
Thanks for the issue report. COA should not be tick after firmware update. I will report this issue internally.
Status update. This issue will be fixed in next firmware.1
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
