Zyxel NWA210AX STILL speed limited?
AP is connected over 2.5Gbit to a Netgear MS510TXUP with a 10Gbit link to my NAS.
There are some points to share with you.
1. We use the shielding room to test the network throughput can be 1500Mbp for uplink and 1200 Mbps for downlink.
2. We use the iperf tool and the speed between 600Mbps~700Mbps in our office. In complex environment.
The device ‘s linkspeed will changes(for example 2400 to 1400) because channel width 160 is easy to overlap and it will change modulation type. It will affect your performance. You can observe this situation
In summary, the performance is affected from environment and your result is quite good.
If you want some advanced analysis, you can share your diagnostic file collect at MAINTENANCE page. Or if your device connects Nebula, Could you kindly help us to turn on your Zyxel Support Access from the below path in your nebula for us to confirm the issue?
PATH: Help (Left sidebar corner) >> Zyxel Support Access
Thank you
Zyxel_Jay
For reference I'm on channel 100, have you tested on DFS channels? No radar nearby so its rock-solid stable on this channel, everyone else nearby is pretty much on band A (most routers tend to default to this to avoid potential DFS issues).
I have no desire to use Nebula as I mix and match vendors, being just an advanced home setup.
I will try to remember to pull diagnostics next time I get a chance to test things.
Thank you for your response.
First. Because the throughput will be affected by many factors, the speed test of the internal network and the external network are also different, so can you kindly share what simple network architecture you have? What tool are you using to test and what are the steps? This can help us a lot.
Second, our AP can reach 1200Mbps~1500Mbps with any channel if the environment is clear enough. But in a normal user environment, the environment can not be clear generally.
Of course, if we want to do an advanced check, we need your diagnostic files. So waiting for your reply. thank you very much.
Sincerely
Zyxel_Jay
Switch:Netgear MS510TXUPWired:Fedora Server Intel 8600K connected over Intel X520 10Gbit DACAP connected over Belkin CAT6 patch cable at 2.5GbitWiFi:Macbook Pro M1
ASUS ROG Strix GL703GS with an Intel AX210 M.2 card
Samsung Galaxy S10Usually wired but used for additional testing:
Intel i7 12700F with an AX201
Ryzen 9 5950X with an AX200
Tests run: iperf3, LibreSpeed, file copies over SAMBA.All clients are 2-3m line of sight to the AP on the ceiling in the same room. Speed testing is primarily based on downstream, as I know upstream tends to be a lot more variable. Testing tends to focus on Fedora as Windows 11 has some very inconsistent network performance in general.I've seen the S10 do 900Mbit at 1200Mbit link rate which is insanely good. That's even more impressive given there were mixed clients connected at the time (802.11n and 802.11ac) though they were idle.
The good news is, I just checked on the ASUS ROG Strix laptop in Fedora and got 1.44Gbit downstream in iperf3. So it seems something must have been interfering and right now, its performing optimally.
Its a shame its not nearer 1.6Gbit, but I know 160Mhz is a lot of spectrum to hope is entirely clean at a given moment. This certainly looks promising for WiFi 6e, though I will probably not upgrade until WiFi 7.1 -
Hi @Alex_Atkin_UK
Thank you a lot to share your situation with us.
Any problem can talk with us.
Wish you have a good weekend
Zyxel_Jay0
- 438 Beta Program
- 183 Nebula Ideas
- 6.2K Security
- 446 USG FLEX H Series
- 300 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 434 News and Release
- 91 Security Highlight
